Hello all,
I have a 2010 t5 transporter
I have installed a leisure batterry with split charge system.
I like my interior lights and would like them supplied by the leisure battery instead of the starter battery.
I assume that all that has to be done is to find the 12v supply to the interior lights and replace is with the supply form the leisure battery.
I have tried to find the fuse wich would supply the interior ligths and sticking a wire in instead of the fuse; but the light may require some magic from j519 so they wont work then.
I have been unable to find where the supply for the the interior lights is located, I have found something about terminal 30g; but 2 hours of google give me dead ends.
All threads related to this topic show no defnintive answer.
Can somebody point me in the right direction?
regards,
Ruurd
Thank you PNE and Changa,
I have not yet been this close!
However it appears that my t5.0 is different from t5.1 since I do not have the light brown connector of wich is spoken in marcoe's thread.
I do have have a red and a black one;
Would one of these still have the correct 12v line?
regards,
Ruurd
I am going to shamelessly bump this thread with another question:
What would be a good source to find out where such 12v feed wire would be located?
regards,
Ruurd
