When starting my 2004 2.5 t5 i am having an intermitant starting problem, only seems to happen 1st start of the day, air temp makes no differance, no warning lights on, supplying garage has said it is showing no faults on diagnosis machine.
Heres what happens, let glow plug lights go out, turn key couple secs, starter turns but motor does not fire, it will do this 2 times then start straight away 3rd time, as i said tho only seems to do this first start of the day BUT not every day?? Any ideas welcome.
Thanks in advance
BUMP: maybe a failing glow plug? I don't know but sure you'll get some suggestions.. what mileage has it done?
