Hi all,
My beloved T5 2.5l T32 (2009) has just been dropped off at the garage to investigate intermittent exhaust smell coming into the cab. This really only happens if I'm sitting in traffic and seems to be ok on the road.
Weirdly it doesn't seem to happen all the time.
I queried the issue at the garage and asked for a "ballpark" scenario just so I'm prepared and they have suggested it could be more serious than the exhaust manifold in that they might need to take the engine out to replace a "head bolt" or something. I did a bit of digging and understand that pre 2003 models were prone to issues with the gasket as they were made with substandard materials but after that they should be ok.
The guy at the garage said that because the newer models were made with stronger stuff the bit to go is this bolt or something which means taking the engine out.
They have suggested if it's this it's 2 days work (£500) plus parts I assume.
I'm not very clued up about this stuff as you can tell from this post!! I guess I'm after a bit of reassurance or something from you fine people on this forum that I'm not being screwed over!
Thanks in advance for your help.
Jonny
Jonny
