Hi everybody,
Just discovered VWT4forum so I registered at once.
I live in Paris and own a 1997 T4 Caravelle ACV engine (102 HP, 2.5 TDI)
Have to replace the alternator.
Looking for the process and the mistakes to avoid...
Thanks.
Have a nice day
Pieter
Literally, white van man
:) Bonjour Pieter (OK, that's the extent of my French)
Welcome W:
Have you seen this post about the regulator and brushes, I did this job on my 2.5 AJT 88, can be done in situe with the belly pan off, a little fiddly but quite doable.
I had the warning light on, battery going flat symptoms.
http://www.vwt4forum.co.uk/showthread.php?t=47745
I havent changed an alternator though, sorry
Chris
Thanks Chris,
Yes I saw the video about the replacement of regulator and brushes.
Actually, the problem seems to come from a leak of gas oil in the alternator as the small pipe for the fuel return just above the alt got loose a short while ago. It has been fixed but too late to avoid the leak to occur...!
As the alternator is almost 20 years old and ran 370000 km, I prefer to replace it. The price on the web is not so high (170 € online for a Bosh original instead of 610 € for the same one at the local VW dealer).
Waiting for delivery at the moment !
Pieter
