1 - 20 of 21 Posts
Right people, I am chomping at the bit to buy a T5 base vehicle with the aim of converting it into a camper but am slightly stuck at the first hurdle.
The question is......
Is a T28 a suitable base vehicle or will I need a T30?
Has anyone converted a T28 previously?
I understand the 2800kg/3000kg but how does this relate to the practicality and use of the T5 once converted?
Any help would be great T:
It depends what sort of conversion you're planning to do. The van weighs ~2000kg so you need to think about how much weight you plan to carry (including the passengers).
It obviously depends what your putting in the conversion but without a pop top you could be in the region of 2100kg and more like 2200kg with a pop top.
This would leave you with possibly 600 kg of payload, so 4 people and average gear would be OK, but a load of outdoor gear and roof racks etc could put you close or over the max load.
Personally, I dont usually have a problem with t28's, but 30's are best if you want to be sure.
i got a t28 m8 full conversion it drives the same as it did before the conversion.i think the conversion is a easy pay load for the t28 and sum.19 tdi 102 .T:
No expert but, I have looked in to this myself as i was worried about my own T28 purchase, so into the garage with the bathroom scales and i have come up with the following
Unladen weight (no fuel) with a 75kg driver for a base model T26/28/30 SWB is 1851kg (other VW info suggests its only 1797kg but i have errd on the side of caution)
Leaving you 749 kg of payload assuming you (the driver) weigh's 75kg
A full conversion with Reimo pop top, RIB 2 seat/bed and the std run of cupboards with fridge and table is approx 400kg (according to various convertor websites and a weigh bridge trip by Carl S on this forum)
Full tank of juice = 70kg
The wife and 2 kids = 150kg
Bag of clothes each = 100kg
Awning = 30kg
Water = 25kg
Gas bottle = 10kg
4 bikes on a tailgate rack = 60kg
Inflatable kayak = 15kg
Bedding = 10kg
4 camping chairs = 10kg
Leaving you 70kgs spare for bits and bobs
I think i will be ok with a T28, a 30 would have been better, but i think we will be under, i can always leave the wife behind and only half fill the tank if its close
Hope this helps
Phil
Thanks for the info, I plan on a full conversion so a Reimo roof, RIB bed and all the other gubbins. Mostly just me and the Mrs travelling but may occasionally be 4 of us.
With the info so far it seems a T28 should be ok. I think if I find a good spec T28 now at the right price I will be getting heavily involved but will still keep an eye out for a T30.
Any other info would be welcome. :ILU:
I'm sure someone with better knowledge than me will know the definitive answer but isn't the only difference the rear springs?
My T28 conversion is just completed so I'm off to a weigh bridge next week with it loaded as for a trip will post the outcome good or bad,( I calculate an ullage of 83kg )
Discussion Starter #10
Davemac what have you had included in your conversion? The full monty? I look forward to the results. Do you have any pictures of your T28 beast?
Mines a T28 and a full conversion with pop top and we load her up to the max when we go away never had any problems and she is also towing a beach buggy....T:
Discussion Starter #14
Well that has sold it for me, a T28 looks fine. Thanks for the pictures, you have a good set-up there.
Hi Dave really nice van there it's gorgeous! I'm looking at getting a T5 and now I'm convinced that the T28 will be enough for my conversion. Did you go to the weigh bridge Dave what was the outcome??
Michael
i weighed my t28 on a local scrapyards weighbridge and full camper with bed/cabinets/sink etc it went 2060kg with not much fuel and me weighing 89kg on steel wheels so loads of room for missus and food etc
j
Sounds great cant wait to get started! i didnt but the recent T5 i viewed. does anyone know the best plact to look to buy a transporter? im in Durham! Thanks
As a side, don't forget, worst case scenario, you can have a van reclassified (T26 -->T28 etc). I'm no expert to advise on this, but search the forum, there's loads written on the subject.
1 - 20 of 21 Posts
