I am in the process of installing electrics in my van, and have fitted the leisure battery under the driver seat along with a split charge relay. I bought these from travel volts and followed the instructions to install which im 95% sure i've done correctly.
When i removed the seat again tonight i noticed a very small amount of water ( droplets) around the base of the leisure battery and a very slight pool. Immediate thoughts that the battery is leaking so i took it out and couldn't see any sign of a leak?
battery is brand new, There hasn't been anything attached to draw down the battery so i don't really know what could have caused this if it is leaking acid?
Wondering whether anyone else has ever noticed any water under the drivers seat which might have seeped in or if this is likely to be the battery?
