What you need to do is add a belt to the c pillar of the van. The double seat is not designed to run a double belt.Hi, I have installed the front double in the back of my camper but now i'm a belt short.
Does anyone know if you can buy a double belt to come from the top centre in between the headrests?
Thanks in advance. T:
His he not needing the one that spools up between the two headrests that provides a three point belt for the middle passenger?What you need to do is add a belt to the c pillar of the van. The double seat is not designed to run a double belt.
No probs mat. I've been busy today but replacing the moo valve on the van tomorrow so will get it sorted for you and get back to you.Brilliant that pal. Not sure if it will work, but worth a try. T:
Let me know how much you want for postage.
Ah I may have read your first post incorrectly I thought you had reverted back from a single front seat and some how managed to loose the middle seatbelt from the front (cab area).Yes I am MESMmack, WickedVanz is correct i should put one on the C pillar but the van is now built and it would be a complete nightmare to undo everything now.
Whilst the double was not designed to hold 2 belts, I was thinking I could make it fit... No?
