Hola,
I have had miscellaneous problems with electrics for a little while, and after metering the accelerator pedal connector (voltage too low) I went to have a look at the ECU end in the big black box under the battery. It turns out there was a bit of water in there. Actually 5 inches of water. :jd
So now I need to get it all dried out. I guess I'll have to check those butt splices in the loom etc.. This could be a mess :(
Should there be a drain in the bottom though? There must be some way of draining any water that happens to get in there.
Cheers,
Thom.
