1 - 12 of 12 Posts
Getting more than usual vibration in the van. Should I replace it ASAP or will it be grand for a while?
Change it!!! If it breaks up and throws the fan belt, the belt could get dragged into the timing belt area, =expensive,
Somebody stop me!
Its proper title is a harmonic damper and thats one of the worst i have seen. Replace it and you will be surprised what a difference it will make to the van plus it will save some serious damage if it does give way T:T:
Discussion Starter · #8 ·
Cheers lads, comprehensive result. My head was saying the same but the wallet still had hope for it.
Get it changed I've been told that euro's are now in Ireland is that true ??:)
Here about 10 years that monopoly money.
Thant my friend is 'FUBAR' :cool:
Exactly what mine looked like before i changed it!
Don't forget you need a new crank bolt and diamond washer when changing it as its a stretch bolt.
Also it will be stupidly tight and needs the correct insane 460Nm or 340ft lb torque when re-fitting.
Quite a few folk on here have had them shear off, timing goes out and the cam shaft snaps.
Get it done asap.
I got a virtually new one off eBay for £40
T:
1 - 12 of 12 Posts
