Hi all.
I've finally gotten around to sorting out my rear speakers. I've got all the bits (save for some speaker wire) & I did some exploratory work on the head unit. It seems that the vehicle side of the ISO harness for the speakers does not have the plugs/spring clips in the plug for the rear speakers. I can find (at maplins of all places) standard Iso connectors with wire tails, which I can cobble together a harness for it work, but I was wondering if anybody knew (in the midlands if poss) of a place I can get a ready made harness to allow the rear speaker wires to be secured to the ISO connector?
It needs to have all 8 eight wires coming out of the male plug & only the fronts going into the female socket, with the rear speaker wires ending in tails for connection to the rear.
ps thats what I'll be doing in my van, theres not a lot of space behind the headunit as it is without adding adapter harnesses etc :)
What I did was get an ISO extension harness from Maplin (essentially a plug to socket lead for the speaker side only) & some flat wire speaker cable. I snipped the 4 outer wires (for the rear speakers) & joined the speaker cable onto it (soldered & heat shrinked).
Pretty simple to do & works a treat!
I did the same thing. Better than chopping into the original van loom. T:
