After reading up on here on how to do it, i decided to whip out my..my egr and give it a clean. its a '00 2.5tdi, and there was a huge amount of gunk built up in it. i remeber reading a post on here where someone described the Egr to be like taking a tube and sticking one end up you and the other end up your nose, and i decided there and then i was going to block it up. i borrowed one of the wifes wall paper scrapers and cut out a blanking plate, and after a good spin, it seems like it was a worthwhile job, seems to rev out much easier and a bit more poke low down A:
I removed the manifold and cleaned it. Then I blocked the EGR and delete it on the ECU. I may also block the vacuum tube and cut the electric wires. :D
João
