Just bought some Audi A6 wheels with part number 4A0601025P. I am just wondering if the stand wheel nuts fit before I start taking my old ones off to put these on, and also panicking as read a couple of threads and not sure what the load rating is on these!!!
Can anyone offer any advice please?
Standard T4 bolts only fit standard T4 steels and genuine T4 alloys.
I can't find the exact load rating of the A6 alloys at the moment but rest assured they're no higher than 650kg each....more than likely lower.
Thanks for the reply, I am struggling to find the load rating on these as well.
If they are lower does that mean that I shouldn't fit them to my van? Mine by the way is a 1.9td on a V plate.
If the front or rear axle weight of your van is more than 1300kgs then no.
Check the black plate on the landing panel for your exact weights.
4A0 601 025 L is rated at 620Kg.........not sure what difference the L in place of the P makes but it is a similar A6 wheel.
Some of the S6 wheels are rated at 725kg.
I'd ring Audi who can usually help by giving a link to the relevant TUV Certificate.
You will need different wheel bolts as the originals are M14 with 14mm spherical rad seats and the Audi wheels will require M14 with a 12mm spherical radius seat x 35mm long.
