Hi I have just purchased my first Transporter (2011, T5.1) and it has come with only one key.:* I can't order a new one until the log book comes back from the DVLA and the battery appears to be running flat. Can I just pop the back off the key and replace the batteries or do I need to resynchronise the key to the van? If so can you confirm the process?
Easy, just pop the back off, make a note of which battery it is, it will be probebly a cr2032, don't remove the battery till you have a new one, then just pop old one out and stick new one in, as long as your not too long with the battery out you shouldn't have to resync, you should be able to do it in seconds to be honest,
Hope that helps
CraigT:
