I have had a replacement key cut for my t4, it worked fine for 6 months but now when I crank the van, it starts but the starter motor doesn't did engage unless I turn the key back manually to the non crank position. I'm in no doubt that its the non genuine key that's causing the problem but I guess what I'm asking is which part of the ignition components (barrel/ignition switch) is responsible for the springing back of the key from cranking position?
