Hi all,
I found a print out of work done to my van & on it is the radio key code & also a 5 digit number saying keycode ? What is this for ?
Any advice would be much appreciated T:
More than likely at a guess it's either the code for the transponder built into the key to be recognised by the immobiliser
or it's the reference code if you every wanted a spare key cut by VW (v expensive), the dealer would just order that Key using the code reference and somewhere in Wolfsburg, Germany in a small corner of the VW plant there is a small key cutting workshop, and some wizened old man who know how to operate the key cutting press.....
Although it would be quite funny if the chap at VW Germany Part department just popped out in his lunch break to the local equivalent of Timpson's and got one cut there LOL:
I'm sure someone more knowledgeable then me may step in and offer the correct version ?
