OK, here goes
We have just done the Tour de grande alps in france and the van developed a weird knocking that came and went and is not doing it now we are home annoyingly.
Basically after the first big Col of the trip, I spent a good 20 minutes in third gear, leaning on the engine, to stop me cooking the brakes on the down hill.
Back on the flat and I could hear+feel what seemed like something moving back and forth under the van when coasting which seemed more pronouced when turning, on a roundabout, for instance.
This continued for the rest of the day which was generally done through lowland counryside.
Next morning, nothing UNTIL we did the next big climb/Descent and then it was back again.
The wheel bearings seem fine, all ball joints (top and bottom) have been done in the past 2 years and the track rod ends don't have any play in them.
My first though was a wishbone bushing had gone but it should knock all the time, not fix it self overnight?
I have driven the van since being back several times now and no sign of the knocking so have a feeling this one may take a while to pinpoint.
The only constant seems to be when the van has been worked hard and has got hot and something is either drying out of grease (driveshaft) or a bolt somewhere is expanding and allowing movement.
I guess I am going to be getting a list of torque settings out and spending a day under there checking everything which will hopefully sort it.
Was hoping someone has had the same happen on a big mountain tour and managed to resolve it.
