1 - 12 of 12 Posts
HELP
hi new to the forum and T4s
And i need help i have a knocking noise coming from the front passenger side
and you feel if in the floor with your feet
things i have replaced
top ball joint
bottom ball joint
track rod end
drop links
inner CV joint
anti roll barbushes
new v-maxx shocks all round
and i still have the knocking just had it MOTed and it passed
and i am now pulling my hair out as it is doing my head in
so can sum one help we
but i still love her
Take your cricket ball out of the glove box ????
Sounds like you have changed just about everything
Just an idea engine mounts ???
I have a simila kind of thing on my caravelle but only if I pull away fast ??? It is the only thing I can think of
hi mate,have the same prob with my velle.found its the wishbone bushes that are worn. 4 bushes either side of van, 2 top, 2 bottom. also been told,mark bolt positions before removal,as rear bolts are offset.not certain about the offset bit,but a couple quid on a paint pen may save a lot of heart ache later.all the best,hope this helps. Joe T:
it was the bottom rear wishbone rubber on mine a pry bar comparing left&right soon found it.also check the bottom shock mount bolt is super tight as these can knock as well
Discussion Starter #10
had a good day today thanks to you guys the knocking has stoped T:
and it was down to the lower Wishbone bushes the back one
so thanks alot :D
Just as a quick check.... Remove the shock and try around the block!! Wish I had tried this before I replaced everything trying to stop the knock I had!!!
Hi
HELP
top ball joint
bottom ball joint
track rod end
drop links
inner CV joint
anti roll barbushes
new to this site but thought I’d give you my findings with similar issues.
I had knocking from below gearstick area under floor. Turned out to be heat shield on exhaust came loose. Welded it back on and noise gone. Bottomend sump pan area was knocking and noisy when travelling around 50-60mph.
drained oil out which was low on dipstick but no oil light came on the dash to alert me.
filled with 5/40 semi synthetic, new oil filter and air filter no knocking now. Very happy.
just hope there’s no damage caused with running it low on oil.
let me know how you get on.
1 - 12 of 12 Posts
