With the bad weather kicking in i have noticed that there is rain getting in the back door somewhere! it collects at the bottom of the drivers side window between the glass and the rubber seal. I cant find where its getting in and the door seal looks to be in good condition. I have a converted T5. Any ideas how i go about fixing this greatly appreciated.:*
It sounds more like the window is leaking. If its a factory VW slider then i would suspect the actual slider to be leaking as they are known for it. If its a fixed window then possibly its not bonded perfectly all round. Wait for a dry day, and blast all round the window witha hosepipe with someone inside the check.
Hi, the window was fitted as part of the conversion. I've tried poring water on it, even used silicon sealant between the window and the rubber. Just cant find the source of the leak.
Thanks for the help though.
