Hi all
My indicators seemed dim more so front ones
So replaced with led which made bulb error light on dash light up so replaced again with the bulbs in link below
Led with voltage regulator built in
No these work fine if the engine isnt running but if engine is running they flash a few times and then stop no indicator at all front rear or side repeater! Until you turn off engine and start again then same few flashes then nothing
Any ideas or advice?
4X AUXITO 581 BAU15S PY21W LED AMBER TURN SIGNAL INDICATOR SIDE LIGHT ERROR FREE | eBay
<li> Feature: 1. Built-in load resistor&IC driver: canbus error free, plug-n-play, wide voltage & constant current. 2. Aluminum body: better heat dissipation provides longer lifespan. 3. High power 3020 LED: ultra bright & energy saving enhances luminous efficiency. 4. Glass projector: Strong...
www.ebay.co.uk
