Hi
I'm in a campsite in Wales and my leisure battery is flat. It's been on the van about 4 yrs and has been discharged a lot over winter etc. it's an orange 110 a/ h from tonsure. I've also never topped it up with distilled water.
It charges either rough a sterling charger/ power pack off the 240 v hook up or via the ex aa wiring which is connected to the starter battery via a massive relay which I switch off and on inside the cab of the van ( used to used by the aa to jump start cars etc)
I've been meaning to get a vsr for a while as its a pain remembering to switch the switch to keep e battery charged.
Thing is the vans been on e hook up at home all week charging up nicely. The fridge is on and i set off yesterday and switched the charge switch about half way into the journey. At the site last night the fridge didn't come on ( waeco crp 40) when I checked e voltage across a light fitting it was 10.49v with my multimeter. The fridge cuts out at 10.5 and won't cut in again until 11.7v.
I'll check the battery electrolyte today and top up if needed. Might need a new battery. If so which one - 110ah or bigger. Also I need to sort outhit he charging from the engine. What's best considering I use the van a lot off hook ups and have a compressor fridge, invertor, propex, etc....
Jurassic on here had some sort of sterling battery to battery charger thing. Which one was that and how does that work? I have good thick cabling under the van to the terminals already which I reused from the aa.
Rich
Rich
