can any1 help me i want to run a leisure battery id like to uses this method which i found on here (hopefuly its the right way)
I run a nice big cable from the + of the van battery to the + of the leisure with a 70A relay inbetween switched off the ignition. then power everythin off the + of the leisure battery. when driving the stereo is effectivly off the van battery (down a longer wire) and when the key is out runs off the leisure directly
but im not too sure how to put the relay into it
thank you
which relay, the switching relay. what is it your not sure about. where to put it in relation to batts or how to wire the terminals.
Whatever relay you put in, make sure you put a fuse at both ends of the cable, just before it terminates at the battery + terminals. The reason for this is that you will have two sources of power, one from each battery. If you were to get a short on the cable run, both fuses will blow. Without them, well, a fire could be the result.
I am not sure how you intend to run the relay.
You could take a look at my guide, here.
I used a different method, that was more expensive, but easier to install.
yes i guess the switching relay. i want it to just draw power from the leisure battery when the ignition is off.
jurasik i was just looking at your guide im only running a tv and my dvd paying and radio off mine so i guess i just need to copy your
alternator
battery
vsr
leisure battery
and then just wire up my things too the leisure battery cheers
