Could someone kindly point me in the direction of where I could get a good leisure battery from that will fit under the drivers seat.
I would ideally like something that will last 2 days although I'm unsure if that's possible with fitting it under the drivers seat.
Sent from my SM-G950F using Tapatalk
How long it will last really depends on what you're wanting to power from it and for how long. A set of LED lights in the rear will take very little power. If you're wanting to run a fridge then that's a whole different matter.
I bought my battery from Alpha Batteries - a Leoch Xtreme XR1750 110Ah battery - it will fit under the seat. Off the top of my head I think 195mm is about the tallest that can be accommodated.
Depending on the type of battery you go for, some (ie. gel) can be mounted on their side giving more clearance.
Generally speaking though lead acid batteries are cheaper but may need venting and can't be mounted on their side.
