1 - 20 of 71 Posts
NEW LIGHTWEIGHT VOHRINGER RANGE!!!
LIGHTWEIGHT VOHRINGER VW T4 T5 INTERIOR CABINETS STARTING FROM £595
THESE ARE MY NEW LIGHTWEIGHT VOHRINGER CABINETS FOR SWB T4 & T5 VANS (LWB IS AVAILABLE PLEASE PHONE FOR A QUOTE)
THE UNITS HAVE A VERY DURABLE HARD FACED LAMINATE COVERING ON BOTH SIDES WHICH CAN WITHSTAND HEAT VERY WELL
ALL CABINETS IN THE VOHRINGER RANGE HAVE ALL INNER EDGES TRIMMED SO THAT THERE ARE NO BARE EDGES AND THE DOORS AREN'T PLANTED ON LIKE MOST. THEY ARE HALF SUNKEN IN TO THE UNIT FOR A SMOOTHER LOOK.
THERE IS A SHAPED DOOR ON THE TALL UNIT FOR MORE FLEXIBILITY WITH YOUR ROCK N ROLL BED
ALL VOHRINGER UNITS HAVE THE LARGER PUSH BUTTON CATCHES FITTED
THEY ARE MADE FOR THE SMEV 9222 TO FIT IN ALTHOUGH OTHER MAY FIT
THE MATERIAL THEY ARE MADE FROM IS LIGHTWEIGHT VOHRINGER PLYWOOD IMPORTED FROM GERMANY
£595 IS FOR A SET OF UNITS INCLUDING THE SLIDING RAIL TABLE SYSTEM AND TABLE TOP
THE LAST THREE PICTURES SHOW THE RANGE OF COLOURS AND FINISHES AVAILABLE. EACH COLOUR HAS A DIFFERENT PRICE, SOME CHEAPER, SOME MORE EXPENSIVE SO PLEASE PHONE FOR A PRICE ON YOUR CHOICE
I SPECIALISE IN CAMPER INTERIORS FOR THE VOLKSWAGEN COMMUNITY WITH A CABINET TO SUIT ALL BUDGETS BIG OR SMALL SO PLEASE SEE MY OTHER THREADS AND MY PUBLIC FOLDER ON MY PROFILE FOR DESIGN IDEAS AND CHOICES
I CAN ALSO MAKE CABINETS FOR OTHER VANS AND TO OTHER SPECIFICATIONS TO SUIT YOUR REQUIREMENTS
TURNAROUND TIME FOR CABINETS CAN VARY FROM 1-12 WEEKS, PLEASE PHONE TO CHECK AVAILABILITY AND TURNAROUND TIME AS IT CAN CHANGE DAILY
DELIVERY CAN BE ARRANGED FOR £60-£100 THIS WILL BE BUILT UP ON A PALLET SO NO ASSEMBLY REQUIRED. PLEASE PHONE FOR A DELIVERY QUOTE THOUGH
BEFORE I COMMENCE ANY WORK I DO REQUIRE A £50 DEPOSIT THROUGH PAYPAL
THANKS
Discussion Starter #2
Carbon Fibre with Black Trim and Tambour Door
This was a unit built for a Vivaro van, the tall unit is 4" thinner but just an example :)
I do use the cheaper boards mate just depends on people's budget. I do plain mdf from £125, so big saving if your on a budget :)
Puntinella unit that was actually built for a classic Land Rover ambulance although it is the same dimensions. I suppose this design could work with a RIB bed?
1 - 20 of 71 Posts
