I drove through a large puddle a while ago and the van went into limp mode when restsrted. Code 17964 negative deveation in pressure. So i,v changed all vacume pipesand no better so just put new n75 valve on cleared the code. Was ok until got it into 5th on motorway and back into limp mode and code is back. Any one got an idea what could be up with it. O its a 2.5 102 T4. cheers.
Waterlogged air filter or as above waterlogged/damaged maf is my suggestion. New style wings with the vnts have a tendancy to draw in water, no such problems with my old girl! Good luck getting it sorted bud :ILU:
Cheked intrcooler and pipes all look ok so blanked egr off went for drive and its flat as fart. Take blank off tha mora n try again.
It,s doin me heed in.
Good call mate looked at wire loom from bulk head to ecu and found two wires rubbed through a bit so fixed them. Took van out and it had less power than before so took blank off egr vavle and turbo pulls better from 2500 rpm.Any ideas what else i can try to get rid of this 17964 code. Thanks all.
Right had block 11 on its the nearest thing i could find. Cal pressure 1081.2 Act pressure1009.8 12.8% Then when in limp mode reading was same apart from 68.1%. i dont know what that means.
Had it on means block 11 started it but when i have a look at saved data it says not running even when i,v been for drive.What is duty cycle 12.1 % then in limp mode it,s 68%.
