Hi all, does anyone know what coulour wire i can take a feed from on the ignition switch of a t5?
Ta
you can get a feed from your light switch. as you open the drivers door there is a side panel on the dash, take this off and there you can see the rear of the light swith. there will be a black and yellow cable you can take a fed from this.
hop this helps
Sorry to hijack your thread, I need to take the ignition live to my stereo to stop it draining battery, how do I do this? Where do I pick it up from and do I need to fuse it? What colour wire am I looking for
Brown/green at fuse 19 in fuseboxT:
hop this helps
Hi sorry to high lack your post but I have the same issue, I have found the black and yellow cable in the light switch plug but there are 2, does it make a difference which one I use. many thanks
