I'm just about to start my conversion before spring finally arrives! I have bought some load lashing point plastic trim pieces but did not realise at the time that I will also need spacer washers. Does anyone have a part number for these or better still have any lying around that they do not need?
Also, can anyone please let me know the size of spline/torx bit that I need to remove them.
Thanks, Phil
I too would like to know what sort of tool you need to get the bolts out. Managed one with a big hex bit but the other at the back won't budge and I have rounded the teeth on the bolt a by bodging it the wrong bit :eek:
Doesn't look like a torx bit would work as it has too many teeth. Anyone know where I can get the right bit from? Halfords don't stock them.
Monty
I used a spline drive socket kit which I purchased from a local auto factor and cost about £10. T:
