I have a 2005 shuttle 2.5tdi. I'm wondering where the heater resistor unit is located for the rear blower. If someone has an exploded diagram it would be very helpful. I have search the forum and can't find anything.
Discussion Starter · #2 ·
Both the front blower and rear blower only work on position 4. From my reading on this forum it is the resistor pack that is at fault. Again through this forum I have found the location for the front cab resistor pack. I just can't find where it is located for the rear heating. Anyone know??
I found it. Simple to remove. Open the boot door. At the right hand side is a panel that gently levers out. The fan unit is here. Undo two 5.5 bolts undo the wiring harness. Less then 5 mins.
