1 - 20 of 83 Posts
I could really use a lightbar at the moment as i do a bit of driving in rural areas in winter and my eye sight needs all the help it can get.....i like the look of the slimline single ones but they all seem to be in USA.....anyone got any links or fitted one so i can cheekily copy idea ?
Rhanks all.
There was a trader in Camper Mart that had LED lightbars, various sizes, the widest one had a slight curve to it, that one was about £100 if I remember. I cant remember his trader name, I've had a look at Camper Mart's trader list, but can't see a name that rings a bell. He's at a lot of the shows, specialises in all things electrical, head units, reversing cameras, TVs etc..
Maybe someone else might comment and remember :*
Looked at doing this a while for exactly the same reason as you Linesy . T:
A mate of mine has one of the front of his car and it's awesome performance but it's a cheap Chinese one and does tend to suffer with condensation .
Reckon you're right with 37" and slimline so it's not too in your face and also isn't blocking too much airflow .
My plan was to stealthily mount it just behind the grill to make it more aesthetically pleasing but the knock on effect of that is the shadowing of the grill itself .
Curved will be sweet so long as its not too dissimilar to the curve of the bumper .
Looking forward to seeing how you get on.
Discussion Starter #10
Started install but ran out of light , how ironic is that......anyway went with deeper higher power (1260w) curved bar.....so far so good, just got to fab brackets and install wiring loom....awsome power, like a summers day when switched on !T:
Special Rapporteur
The 1260W rating must surely be an "equivalent" rating, not an actual one???
If it's the real rating, I hope the wiring and switchgear can take the strain!
Special Rapporteur
Ah, ok - so probably around 20 Amps I guess - which should be around the same input power as 4 halogens. Be interesting to hear how well they throw light forward - it looks as though each LED element has its own lens/reflector assembly built-in?
1 - 20 of 83 Posts
