Hi everyone,
Today, I got in my Van and the engine wouldn't turn over. When attempting to start the engine, the key clicks into the last position but doesn't fire up. I can't hear any clicking from the starter motor, it's as if the battery is flat but it has been charged up and is fully charged after testing it and all lights work correctly. The van also won't start with a jump either.
So this leads me to know it's not the battery.
On researching the engine bay, I found a loose wire which I hadn't noticed before.. It has a blue, green and red wire inside but the green and red wire had been bent back and taped up so clearly not in use, only the blue wire was making any contact with something.
I also noticed another wire further down in the engine bay which looks like it has been repaired previously with a spade connector.
I have no idea if these wires have been loose the whole time I've owned the van (surely they need to go to something!?) and I also have no clue as to what these wires are for or if they need to be connected?
I am hoping someone can give me some indication as to what these wires are for and if they will resolve my non-starting issue! Or if there are any other suggestions as to what is causing this?
I've included some photos below to show the wires.
Also my van is a 1998 T4 Caravelle LWB 2.5 TDI (ACV Engine)
Thank you so much!
Hi, my guess is that the spade connector at the bottom is supposed to be on the spade terminal on the starter motor (on the solenoid) that would account for the starter not turning, this happened on ours.
The other wire could be from any number of places.
Full of Cr*p....
Seeing as the other wires come out from a hole someone made in the grommet, it was likely a bodged in alarm that the previous owner decided was useless and removed it.
Any VW wires would run inside that grommet.
Thank you so much Jungle-Jim!
The spade connector was for the starter motor.. Must've accidental come off somehow..
I plugged it back in and the van fired straight up! Saved me many hours of head scratching! Thanks very much!
You are definitely right.. It runs from the dash to the terminals on the battery with an inline fuse so definitely an aftermarket alarm or something. Thanks very much for your help!
