Hello guys,
I have an ongoing issue with my 2.5TDI AJT engine with assumed low charge air pressure. This engine has the EGR blanked and EGR intercooler removed. Previously been remapped.
The problem - While sitting on the drive and someone revving the van to 4k revs the turbo arm only slightly moves at high revs. When the van is being driven it is gutless and slow and feels like straight 5cyl 2.5l no turbo. Struggles to push past 3rd gear on steep hill. Top speed up hill under 40 mph. This is not a camper, just an empty day van.
Backstory - After starting issues presented, which resulted me in changing two looms between ignition and fusebox, and fusebox and engine, new glow plugs fitted. Van would then turn over, but wouldn't stay running. The van was then taken to a garage, where it sat for months while it had ongoing issues with the garage. Van was removed again 7 months later and since then turbo not kicking in. I believe by this time the van hadn't been used properly for around 1 year. The van wasn't started at all for a 6 months period during this time.
What I have checked/done since receiving the van back:
It seems to me that there is low charge air pressure from the compressor side of the turbo, as I can get movement on the actuator using bike pump at under 20 psi. Is there anything else I should check which can affect charge air pressure? Any known leaks etc?
Any help would be appreciated as I am really scratching my head with this one.
Many thanks for taking the time to read.
Joe
- Vacuum hoses checked and replaced using diagrams.
- N75 solenoid checked for operation using bench power supply, resistances checked between terminals and 12v power at cable on van between pin 1 and earth.
- N75 swapped with EGR solenoid to rule out the solenoid.
- Banjo fitting on turbo compressor removed, cleaned and refitted. Washers present.
- Pressure hose taken from the turbo compressor (banjo) and fitted directly to the turbo actuator, thereby bypassing all vacuum hose and solenoid assembly. Van revved to 4000 rpm and very small movement at the turbo arm.
- Actuator checked with the hand pump, doesn't look like it leaks.
- Later checked the actuator using a bike pump and the actuator has full turbo arm movement under 20 psi (i cant actually read what it is as the pumps minimum value is 20 psi and the actuator operates halfway between 0 and 20 psi).
- Checked the air filter for blockages, old but not blocked.
- The turbo arm has been manually operated, its stiff but can be moved by hand.
Joe
