Hi all, Recently I had an interittent problem with the engine suddenly losing power temporarily. I knew the oil was low but found that it was really low. have topped up oil, and cut-out problem seems to have gone away. Is this a coincidence?
Probably not, was the oil light on? does it work?
1. Turbo may not spin up if it has one
2. Low oil pressure may not fill Hydrolic Cam Followers enough meaning late opening early closing valves
Not to mention you'll knacker the engine :eek::eek:
Lucky if it still lives, lets hope so:D
