There have been a few comments/questions about cut bolts used to hold the lower ball joint onto the hub.
I had seen a few and not really thought about it when I changed ball joints last time as I had new bolts from VW.
But having to unexpectedly change a ball joint after 6 months I bought a new ball joint which came with bolts.
Fitted it and all seemed fine. Took it for a drive and then for the MOT where it failed. The bolts were not holding the ball joint tight and there was about a 6mm gap. Well it seems that the aftermarket bolts are not the correct length which explains the cut down bolts.
OE spec is 20mm long. Some pics.
Left to right.
Aftermarket. Cut down and original.
Note also the different head size.
