Hi I have just had some 40mm HandR springs fitted to my T5 and front is very much lower but back seems high still. There is a definite difference in levels. Is this normal?
I would point out it is a T5 LWB T30 but has T32 front suspension (for some reason)
If its just been done it will settle but it is the standard rake of the van
Rear is higher to take a load it probably will sit higher on the rear
I run standard and replaced the rear springs (both) when one snapped
At first looked like it was on stilts! But did settle down (y)
