ok read a few of the how to's but not completly happy doin this meself so anyone close to me know a place or willing to do this? can cross your hand with silver or beer LOL :ILU:
Definitely give it a go, it's suprisingly easy... Take your time, follow the steps carefully... Just make sure your van is well supported in all the right places... T:
Hi, I had to remove the spring and washer from steering column . I refitted both but the steering is now ‘ notchy ‘, and hard to turn round corners! Have I knocked the special washer down too far ? And compressed the spring too much? I have been having problems with this for months and it’s...
Ok it is time to get this done
As with most things it is always good to get some pics so you and check how things should be fitted.
The bend in the middle of the ARB.
And the old drop links
My van seems to have developed a knocking when turning right only, generally at low speeds.
I'm thinking likely CV joint?
I'm meant to be heading from Manchester to the south lakes this weekend - is it desperate to get it sorted before then?
I have had my Gaz shocks on the van for only 2-3 months, but had no end of issues with them, could never get them adjusted properly, each setting wasn't the same on each shock and when I did get them set up ok the settings would change after a weeks driving!, I wasn't convinced on the ride...
Hi there,
So my steering column bearings on my 1991 T4 are starting to disintegrate and I had shards of metal in the steering cowling and some bearings have fallen out.
I've had a mechanic look at it and he says I need a new upper steering column 'from the UJ's up'. I'm not totally sure what...
