i am looking to drop my t5,does anyone know if the springs that you fit are generaly stiffer than the originals to allow for lack of space,only i run 20inch rims and just a bit concerned about hitting the wheel arch.i can have 40 or 65 mm fitted for about 400 notes but cant get a solid answer on the stiffness of springs,the only other option is the ajustable suspension kit ,but the bad news is the kit alone costs about £1300 OUCH!.
i know its a newer vehicle but the principle must still be the same,any advice would be great..the only downside of lowering it is bodykits and kerbs dont match and where i live there are lots and lots of bloody speed humps.
use h&r springs lower by 40mm but make sure you by the right axle wait springs you can check the axle wait on your vin plate to order approx cost £280 to £300 with postage.
