I’ve had a look in the forums regarding lowering, but it can be quite confusing. Can anybody help, I have a T5.1 full camper conversion and looking at lowering it. I have 20” 275 40 wheels. I assume it’s on standard springs, the height from centre of wheel to arch is, front 445 and 415 rear. I’d like to lowering it and level the rear sag as well. I’m thinking of 35-40mm lowering springs. If I lower it by this much will the rear sag level up with new springs? Will I have any issues with the tryres rubbing?
This is the front wheel
This is the rear
Any advice would be much appreciated
Super Moderator
I would suggest looking at Coilovers instead of just springs. This way you can finely tune each corner until your happy with its position
You have to also consider hold old or tired your original shocks are .
Its anyones guess what it'll do with new springs on but you dont really wanna be paying out to do the job twice if you dont have to .
Where are your water tanks, I lowered ours 40mm all round but the first time we went away the water tank in front of the spare wheel bottomed out down a rough road a couple of times so I decided that was a non starter & put the back up again and just left the front lowered.
