hi all wondering if anyones had same broblem with the engine (2003 88bhp ajt)start up and idles just fine after around 60 secondes then the engine gets lumpy like its running on four cylinders only lasts for around 60-90 seconds then its fine after that this is only from cold no other problems with it apart from one that might be related the idle speed has jumped up and down a little after a fast run thats only happen twice though since ownership of around a month,timing belts were done two weeks ago and has idled lumpy before and after belt change from cold engines done 77k will try to post my t4 pictures up when it stops raining,steve
