Has anyone got any plans to make these?
or can give me the length of pole used so i can order it up today pre cut?
ta
dan
Doh, why are the answers always so simple, i was having one of those days yesterday and didnt even think of that!
will try and make some in work as im an engineer and can get metal trade..but need help with bracket as cant see in the germain page on how to do it
The brackets are literally an "L" shape in flat bar welded top of the "L" to the side bar so the tab bit at the bottom of the "L" points upwards. One end bolts to the rear suspension mount just forward of rear wheel the other behind front wheel near the jacking point (look for the box section with 2 holes in the bottom).
It's clear once you look under your van.
