Dudes,
more help please.
bought a Lycksele single how the hell are you guys fixing it to the floor of the van and have any of you made it quick release so you can whip it out if you need the full length of your van?
thanks again
FD
hi there, i had one of these in my van and just popped the plastic bits off the bottom of the 'main' frame and had a mate weld some plates with holes either side of the leg for attaching. i put threaded bolts through the floor and used 'butterfly' nuts on top so i could remove easily by hand, did mean there was a few studs sticking out of the floor when bed removed but it worked well...
