Right went to start the van today turn the key get the glow plugs fired up go to start and it makes a Big Crunching noise... I suppose the only way to describe it is the crackle you get on a two way radio... But louder!! Has anyone got any ideas what it could be?? As it doesn't sound good and won't start!!
Hi Mate
Where is the Crackle coming from?
If its inside the cabin could be the Ignition Switch
If its under the bonnet it could be started shorted
Mike
Is the batt charged ok if yes and it does it every time you try the starter put it an gear then push the van to move turn the engine over a little ,then try again if it starts with no probs then the ring gear is damaged. If still crunching then it's the starter.
