On a T4 with a 1.9 TDi conversion from a golf.
I'm getting a fault code, Manifold absolute pressure sensor.Before I open up the ECU, Can anybody please tell me what driving symptoms this will cause?
Thank you.
Hi is it saying a fault on the map sensor or map sensor reading to high as in getting to much boost from wastegate stuck or something?
I only have a cheap code reader from ebay and not vagccom but it give a code of 00575 if I remember correctly.
I've made up some plates to blank the EGR. from what your saying it would be a good idea to fit the sooner rather than later?
