Hi i need some advice on where i can go and buy a wing mirror for my t4, want both sides to match. can anyone help please:)
Its about time I showed up
Might be worth sticking one of those little curved blind spot mirrors on it.. Will look rubbish but better safe than sorry T:
LOL:tryed that didnt really make it much better still makes the van look good:D and thats a price we have to pay !!!
^^^ If you put the long one on like me you have to remove the mirror (crack every time:mad:) Place a small washer under the outer two screws of the swivel plate and cut the three inner stops (part of the aluminium moulding) to get it to angle in enough. Otherwise you can only see whats about 2metres away from the side of the van. I've got a mirror in bits at mo, will try to get a photo on to show you whats whatT:
Washers behind the two gold screws arrowed (between swivel base and main base not under screw heads)
Cut the other three stops on right arrowed (DREMMEL or similar)
Hope this helps
