321 - 340 of 497 Posts
Discussion starter · #322 ·
I've spent the last couple of weeks rebuilding the interior I ruined years ago before I moved over to Norway. The Mrs refused to go camping the state he was in inside. It doesn't help she's used to the Westfalia interior in Norway which is brilliant.
As I was starting, I noticed a problem where the floor was damp under the right-hand side window which filled me with dread immediately! Got my mate around with a hosepipe and it was coming through the bonding on the window! Upon further investigation, it looks like someone has either tried to break in or pinch the window glass! There's a number of small chips in the paint that are new where it looks like a screwdriver has been used to try and break the seal. Needless to say, I was a bit upset :mad::mad::mad:. You cant have anything nice these days. We resealed it for now but the window will probably have to come out again to be rebonded at a later date.
(You can see the mess I left before :whistle:)
It was coming down the pilliar here and getting into the ply flooring at going to the back of the van. It looked recent as the water was fresh and the floor wasnt totally soaked. I had to lift up the whole floor with the bed out to dry it all out
Discussion starter · #323 ·
Fitted the new solar panel I've had tucked in the garage for a few months. 150W Xplorer kit with a Victron MPPT controller for £200 from Alpha Batteries. With a stroke of luck, it fitted into the roof rack gap with some extra Z brackets off eBay.
Rather than have to drill a hole in the roof, I've run the cable back down the gutter to the back door and under the door seal, into the fog light entry and into the van there.
Look what was lurking under the seal when we pulled it out! :alien:😮
Discussion starter · #324 ·
The rest of the interior needed starting again so I bought the 6mm ply lining kit from Custom Design Shop on eBay for the walls and the roof too. I ordered the carpet from Mega Van Mats after my mate got his from there. Guess who ordered the wrong colour :LOL::ROFLMAO:
Turns out I quite like the two / three-tone nature of the interior. Works quite well. Maybe it was fate. This carpet is much nicer than the lighter grey stuff that was on when I bought it. My mate showed me how to carpet the panels which helped a load. He did the big panels and I carried out with the other bits and bobs. I'd also found the window surround I'd had for years of a lad on Facebook that works really well.
I replaced the roof lights too, going for 6 instead of 4 like before.
Discussion starter · #326 ·
Boxed the heater back up with some extra hidden storage next to it. I've still got to work out what to do with this bit. This section is lower for the new Dometic CFX-35 fridge to replace the old Aldi coolbox which was always a bit of a battery drain.
Got a standard switch panel from Amazon but replaced the voltmeter and USB with a kill-switch and better USB 3.0 port. The NASA BM-1 compact multimeter went back in too.
Discussion starter · #328 ·
At the same time, the new LED light bar was fitted. Its a Strands SIBERIA Single Row LED Bar 50" 12/24 Volt E-Approved. Single row looked nice with the low profile. I didn't like the look of many of the other cheaper options. This was one on pre-order from KUDA-UK waiting for shipment from Sweden at the time. It needed a little section grinding off the check plate deflector by Mr Brek (who also did a neat rattle can job too which looks way better! (y)(y)(y)). It needed a bigger 240watt wiring loom to replace the older one that was still fitted from the old light bar. Its got a neat extra row of lights that canbe switched from white to amber with an extra switch. I ran the wiring in at the same time as the solar panel.
Discussion starter · #329 ·
New horn in time for the MOT. The bugger had stopped working. The old one was in a right old state down below (always a daft place to put it). I bought this dual-tone set at Busfest a few years back. Needed a loom as the two horns were bigger than the existing 10A fuse. Turns out the old horn was ok and it was the slip ring on the back of the wheel. The new horn sounds way better though 🤘
Discussion starter · #330 ·
One problem before the MOT is the projektzwo sidelight bulbs. The holders are ****! I've used both pairs off the lights I had and they are intermittent at best with normal or LED bulbs. It passed the MOT as it was but I've got a couple of spares coming from Germany of an E30 BMW to try.
I got the lights re-aligned too. I was bonged eyed for the last few weeks 😣
You've been busy Matt, new rear set up looks good! Camping set up looks spot on too, can't wait to get an awning and have some proper camping time.
Fording looks a cracking bit of fun, how many times did you go through it?
Discussion starter · #334 ·
Chees (y) Aye, it's about time the interior had a bit of attention. We went through the ford a few times as it was a shortcut into the village. I kicked her out to take a photo from the footbridge. Someone took an articulated truck over once and got stuck :ROFLMAO:
