Not sure if that's the correct name. The blank panel next to the speedometer? Is it possible to activate it for all the relevant info it can provide
A download from VAGcom perhaps, or is this just not possible without major surgery?
DIS - Driver information system ?
Don't know. Called maxidot on my Skoda apparently, but your description sums it up much better. Shows mpg,range,average speed temperature and stuff.
I was made ip when I saw the panel, but left slightly disappointed when nothing appeared on the screen. I love all that info stuff.
Full of Cr*p....
It's the "Multi Function Display"....and involves a load of wiring (to the ECU as well as other places).
Obviously the dash panel has been replaced at some time.
If you search in the Electrical thread, I think there is a whole section about retro-fitting one.
Someting like "MFD Goodness"....?
I think was only fitted to late model vans, as an option, but I may be wrong.
