Pedal box guru
Just inside the drivers door on the "B" pillar are some stickers, one is from the people who installed the airbag system this sticker gives you the maximum load (with airbags fitted)
If you have removed the airbags then you are back to the original VW load rating which is on another plate in the same location.
Cheers Trev.
All the tech stuff is now tagged...
If you hit the Search button, then Tag Search, you'll find the Tag Cloud...
Or you could click on the weight (it's easier to Index) tag below...
