Hello,
can anyone recommend a good mechanic in the Swindon area, mobile would be great. Since a battery replacement My van will start but won’t rev. Then brings on engine light. Tried new accelerator pedal unit, not sure what else to do.
Thanks,
JC
Thanks to Spedwing who came over and tried to read the codes. VCDS would establish communication but could not get a response from the controller. tried Vw group specialist but they can’t look at it for another month. 🥴 so I’ve had the battery and Ecu out today, all of the connector pins look fine. Not really sure what to check next.
Have you checked the loom over the top of the engine? It's a common place for broken wires
Discussion Starter #8
Right, checked the loom at the bulkhead and across the engine, it looks almost like new. Also tried another Ecu, problem still persists. Was gonna get into the fuse box and dash and start checking for any shorts to ground there? Anyone got any other potential causes?
