Hi every one first post and hope some one can through some light on a few questions.
On the way back up from newquay two weeks ago my 1.9td abl engine van decided to die!. Going up a hill minutes before the red warning light for the fluid came on and the temp gauge did not rise above half.
On looking under the bonnet I just caught the temp sender on the head MELTING OFF. You could say it was a bit hot?
Questions are
1, Has any one had this happen and what was the conclusion.
2, has any one put a 1z engine in a td but using the pump from an abl engine or do you need to keep it a tdi.
3, what other engine code will fit using my ancillaries of the 1.9 tdi
Any advise would be a great help
jas
yip as above , my van has been running a 1.9tdi engine on the standard t4 TD fuel pump for around 2 years odd and its been perfect .. T: plus youve always got the option to fully convert to tdi if you feel the need ..
