1 - 14 of 14 Posts
Can anybody do me a favour,
I need to know what wire goes where between the yellow clock sprind connector and the MFSW connection on the T5.
Anybody help have searched the WWW but can't find anything for the T5.
Van is 2011, I have added the 2 repair wires they are fine. Just need the wiring from the yellow plug to the MSFW connector.
If you're talking about the harness / loom behind the airbag, it's usual to buy that complete which vary between £15 & £50 depending where you get it. I don't recall ever seeing the connections for that explained.
Discussion Starter #8
Yds
Yes this is one I have the loom but don't think the wires are correct, i just need to know where 1 to 5 of the MFSW connections go on the yellow connector.
I have done all of this, I need the wiring from the yellow plug on the clock spring to the MFSW. o_O
Discussion Starter #11
I have a loom and just need to know where 5 wires go, why spend money on something that can easily be adapted with the correct info. I am sure many other people would benefit from this info also.
Special Rapporteur
The problem is that (IIRC) two of the wires in the loom serve the airbag - and you have no way of testing whether the wiring that some random person on the internet suggests will work in a crash. Well, ok, you can test it, but that's more expensive than just buying the correct loom!
On balance, it doesn't seem to be a good idea for any forum to encourage people to mess about with the airbag wiring (simply because it's safety-critical and cannot be DIY tested).
If you really want to DIY then it would be a good idea to pay for a short duration subscription to Erwin, because that way you can see the exact wiring for your VIN.
Discussion Starter #13
I am not touching the airbag wires.
This is the problem I have.
Wheel is a Polo 6c and only the right buttons are doing anything, including turning radio down and selecting stations. I have an after market Kenwood radio and have noticed that when doing a scan the radio control module is not recognized.
Discussion Starter #14
Scan.
Date: 2020-02-06 14:03
VIN: WV1ZZZ7HZCH011448
Car: Volkswagen Multivan
Year: 2012
Body type: VAN
Engine: CAAC 103 kW (140 HP) 2.0 l
Mileage: 58140 KM
01 Engine Control Module 1
System description: R4 2,0L EDC
Software number: 03L906022CH
Software version: 9126
Hardware number: 03L907309K
Hardware version: H43
Serial number: 00000000000000
ODX name: EV_ECM20TDI01103L906022CH
ODX version: 002012
Long coding: 01194010232400080000
Trouble codes:
U111200 - Function limitation due to implausible message
static
Date: 2098-12-09 13:51:59
Mileage: 58147 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Engine speed: 858.50 1/min
Normed load value: 29.4 %
Vehicle speed: 0 km/h
Coolant temperature: 15 °C
Intake air temperature: 10 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.360 V
Dynamic environmental data: 209628108940108BC8108C00108DFF1663000012D50002108E01
03 Brakes 1
System description: ESP MK25A XT
Software number: 7E0907379H
Software version: 0107
Hardware number: 7E0907379E
Long coding: 508724AD89A50A9624A69175A96610
Trouble codes:
No trouble codes found
04 Steering Angle Sender
Trouble codes:
09 Central Electrics
System description: BCM T5GP H+4
Software number: 7H0937087H
Software version: 0251
Hardware number: 7H0937087
Hardware version: H47
Serial number: 0429 162110545
Long coding: A0A0393A0E612411802848102C2B8CD10000430F60060000300000000000
Subsystems:
System description: J386__TSG_FT
Software number: 7E0959801C
Software version: 3311
Hardware version: 003
Serial number: --------------------
Long coding: 050000
System description: J387__TSG_BT
Software number: 7E0959802C
Long coding: 040000
System description: LIN BACKUP HO
Software number: 1K0951605C
Software version: 1501
Hardware version: H05
Long coding: 000000
Serial number: ÿ1K0951605C ±501
Long coding: 000000
Trouble codes:
10 Parking Assistance 2
System description: PARKHILFE 4K
Software number: 7E0919475D
Software version: 0013
Hardware number: 7E0919475
Hardware version: H11
Serial number: 47301112902405
ODX name: EV_VW75XParkAssis4K
ODX version: A01006
Long coding: 108001
Trouble codes:
15 Airbag
System description: VW10Airbag009
Software number: 7E0959655B
Hardware number: 7E0959655B
Hardware version: H06
Serial number: 003HL0062ZSQ
ODX name: EV_AirbaVW10BPAVN750
ODX version: A01026
Long coding: 000000000000000000000000000000003039
Trouble codes:
17 Dash Board
System description: KOMBI
Software number: 7E0920960E
Software version: 0305
Hardware number: 7E0920960E
Hardware version: H03
ODX name: EV_Kombi_UDS_VDD_RM09
ODX version: A04113
Long coding: 460A00
Trouble codes:
19 Gateway
System description: GW-K-CAN TP20
Software number: 6N0909901
Long coding: 042300
Trouble codes:
25 Immobilizer
System description: IMMO
Software number: 5K0953234
Hardware number: 5K0953234
Serial number:
ODX name: EV_Immo_UDS_VDD_RM09
ODX version: A03009
Long coding: 000000
Trouble codes:
56 Radio
Trouble codes:
1 - 14 of 14 Posts
