Just bought our first T4caravelle (2001) and cant work out how to remove the middle 3 seats. These appear to be bolted in individually. Fitted into mushrrom bolts.
Have tried following instructions in manual, but no luck. wondered if anyone had any tips?
Meithered to death
Lift the lever to relase the seccuring catch then with a big mallet or similar hitting device belt the seat legs to move it towards the back of the vehicle.They are often stuck if they have not been out for a while and take some aggressive persuasion to remove.
If its anything like mine, (99 LWB Velle), the seat by the SLD needs to be pushed towards the middle of the van to get them off the mushroom bolts. Push the lever down as hard as you can. Stick a load of WD40 on the bolt area as well if not been moved for a while.
Middle seat pushes back.
I have twin slider so off side seat pushes to middle again.
Hope this helps.
Andy
