I've had a tinted middle window installed on the off side and i've carpeted up to the edge of the bodywork and trimmed (although not very neatly!) I was hoping to finish off the edge with some 'U' shape rubber seal all around but as you can see in the photo, there is a load of silicon/glue that fills up most of the gap which means I wouldn't be able to push the seal on...
Does anyone know anywhere that sells an 'L' or 'r' shape rubber seal that would cover the carpet and the silicon? It wouldn't necessarily need to be pre glued as i could use some 3M foam tape to stick it. Thanks
That's awesome thanks! Definitely the widest range of trims i've seen so far. Hopefully i can find something suitable there :)
